complex profile for wall
Hello
I need guidelines in the wall modeling process.
Here is the segment of a wall.
In the first part, I need to apply Tiles on one side of the wall.
In the 2nd Part, there are Tiles on both sides of the wall.
In the 3rd part, there are tiles finishing on one side.
To draw this segment I used different complex profiles. It seems my process is not ok. Cause
-There is a line between the connection between the profiles. (See the attachment)
-This process requires extra time.
Can anyone please suggest me which process is effective for modeling a wall. Is there any best practice for modeling a wall with finishing.
N.B: I use Archicad 23
If you use the same material and if your walls are coplanar, there is no line.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
Jp1138
The reference lines for the different walls should be continuos or lines may show in unexpected places, so I would check if that´s the case.
ARCHICAD 29 SPA (as long as the server works)
Windows 10
