2024-08-06 10:55 AM - last edited on 2024-08-06 11:00 AM by Barry Kelly
I was trying to convert fills to zones and I was able to do that in one file. I copied same elements to a new file and tried converting fills to zones using magic wand and it says its not a closed polygon! Whats wrong? the first file is a file migrated from version 26 and this is made in 27. Please help! thank you.
Operating system used: Mac Apple Silicon 14 Sonoma
Solved! Go to Solution.
2024-08-06 09:42 PM - edited 2024-08-06 09:44 PM
After you click on the Zone Tool, Check your Construction Method settings. You need to have one of the first two methods selected for use with the magic wand on a Fill.
2024-08-07 05:56 AM
Thank you! it worked!!
