copying elements between stories
Hi all,
is there away to copy building elements between stories. for example, I am trying to copy interior walls from the first stroy to the second story.
thanks
4 REPLIES 4
Have you ever try copy/paste (ctrl+c/crtrl+v)
It is also change the level of the element to the story level
Dwight
On Story 1, select and copy the specific elements you want
2: Go to Story 2 and paste them. They will be placed at the same height relative to Story 2 as they were in Story 1.
An alternative method for copying ALL elements of a given type (all walls, for example) between multiple stories is within the Stories dialog.
Dwight Atkinson
thank you Dwight, and miker. I have tried both methods and they both work great.
H
Dwight
You are welcomed. Buy my book.
Dwight Atkinson
