corner stair
any idea how to do corner stair type using stair tool?
Thanks
4 REPLIES 4
Jp1138
You can edit the steps and give them any shape you want. Stair structure won´t follow, though, so you could just turn it off and model only steps with the thickness you need.
ARCHICAD 29 SPA (as long as the server works)
Windows 10
To keep the structure following the stair, just create one stair and change the boundary on one side so it is at 45°.
Then mirror a copy on this 45° angle and you have your corner stair - or rather 2 stairs.
Also I have moved the post.
Please try to choose an appropriate section of the forum to post in.
To illustrate Barry's post, this is modeled using 2 Stair elements - one Stair element, then mirrored along the 45-degree line. You will also need to select the 45-degree Boundary of both Stair instances and Hide it using Pet Palette commands.
