I seem to be having problems using the corner windows. In some cases when I apply the corner windows to a corner there still remains a residue of the wall. In order cases the corner windows apply correctly but when I adjust either side ie. increase the length a bit of the wall appears at the tip of the corner. The walls are 90 degrees to each other. I also noticed a bit of the wall appearing depending on the placement of the window with regards to the wall thickness. I have searched the forum and have not found any satisfactory solution. Any help would be appreciated.
	Have you seen the light?
AC 12, AC14, win 7, Hp pavillion dv6 2.4Ghz, 4gb Ram
