create panel ...
any ideas about creating this panel-wall ??
(the blue one )
thank you !!
You could make it with a slab and save as object. Put a hole in it large enough for your window opening exactly as you would form it. Put a section of wall in your opening and insert window.
Gerald Hoffman
Archicad 4.55 - 29-Latest USA
You can use normal wall for the opening. And later with SE you can cut out the figure from the wall.
