‎2009-08-02
08:26 AM
‎2023-05-23
03:01 PM
Rubia Torres
‎2009-08-03 01:38 AM
‎2009-08-04 12:49 PM
‎2009-08-04 12:53 PM
‎2009-08-04 01:48 PM
creative wrote:You need to change the Cut Fill of the roof from a Composite Structure to one of the other fill options.
here the vertical eaves height and roof height are set at 213 & 199 respectively, and cannot be changed(greyed)
how do i change these settings?
‎2009-08-04 06:27 PM
creative wrote:For a simple gable, select the rectangular geometry, not polygonal.
5)selected polygonal method
6)clicked on first & second node respectively
‎2009-08-05 01:47 PM
‎2009-08-05 05:23 PM
creative wrote:This is one of those things where one needs to learn ArchiCAD as a whole rather than jumping into a single tool.
can you please elobrate @ the OVERHANG USING PET PALETTE.
‎2009-08-06 02:27 PM
‎2009-08-07 12:22 PM
creative wrote:One suggestion: I don't know how you are doing the Interactive Training Guides. But if you are only watching the movies and do the steps, then it is advisable to read through the PDF file as well because it usually contains more comprehensive explanation and hints and tricks related to those steps. That can help too.
wow it was so easy.
what do you mean by archicad as as whole ? is learning through interactive traning guide(hungary microsoft office and Massaros house) not sufficient for basic knowledge of archicad, if not please guide me to other sources.
thanks
