‎2009-11-30 11:56 PM
‎2009-12-01 10:31 PM
‎2009-12-02 12:46 PM
‎2009-12-02 02:02 PM
Markus wrote:Hi again Markus,
According to your suggestion I must save first curtain wall as library object.
‎2009-12-02 02:07 PM
‎2009-12-02 11:04 PM
‎2009-12-02 11:23 PM
‎2009-12-03 12:38 AM
‎2009-12-03 01:38 AM
Peter wrote:Hi Peter, Thank you for your help.Markus wrote:I was suggesting opening up the existing 'frame' library part that the curtainwall uses, editing the script slightly to add an extra material definition, then do a 'save-as' and give it a different name. This is what I had done with the object I attached before. My apologies if I wasn't clearer.
‎2009-12-04 11:27 AM
Fuintur wrote:That is different. With align 3D texture you can align the position of texture for certain surface.
Regarding this subject... is it possible to modify the origin of some material through "align 3d texture" in curtain wall bars?
