curtain wall
Hi!
I have to model curtain as on pic attached with this post.
it is facade curtain with no panels, just framing.
Problem I have is when some of the mullions are removed connection of other mullions are not good. In pic you can see red ones are wrong and the blue one is what I want to achieve.
1 REPLY 1
You can just adjust the connection priority strength for the frames.
Either make the horizontal frames stronger or you could make the vertical ones weaker before you delete them.
Not sure why it doesn't heal up automatically when you delete them.
I can understand if you just make them invisible they would still interact but if they are deleted they should have no effect anymore - at least to my logic.
