custom stair with no landings
I' m trying to create a stair like the attached one, with no landings and I have not the option. Does anybody knows anything??
Thanks
The built-in stair tools have some limitations with winders (which have been discussed before) and I don't think there is an option for the layout you are showing. You might be able to use the function to "create stair from selection". I have never used this function so I don't know it's limitations. Otherwise you could build the model from parts (profiled walls can make very nice treads), or use and add-on such as Archistair or the Cadimage stair builder.
David Maudlin
evivas:
Use Create Stair Using Selection (see the Help files), and angle the travel line at the winders, this will take some trial and error to get exactly the desired result.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
