custom toolbar question
Hello all,
I am defining a custom toolbar and I would like to be capable to add some dropdown buttons. But, for some reason, some of them - Trace, for instance - only show as a single button, i.e., no dropdown version.
Can anyone help me out?
Many thanks,
Joaquim
Link
To show a drop down list you need to add a menu, not just individual commands. So, for example, change your List to 'All menus in alphabetical order' and try adding a whole menu. Then you can highlight that added menu and check 'Sticky popup menu' to make it appear as one button with a drop down arrow.
If you don't have a menu that you want to add, you may have to create one of your own first, and use it only for this purpose.
Link.
Link,
It worked as a charm.
Many thanks.
Joaquim
