‎2009-08-16
07:00 AM
‎2023-05-25
04:34 PM
Rubia Torres
‎2009-08-16 11:15 AM
‎2009-08-16 01:32 PM
‎2009-08-16 03:11 PM
David wrote:Can i get step by step, because i am a l
One advantage of using SEO rather than the pet palette option is that with SEO the material of the edge of the hole can be inherited from the operator. For example, if the slab's edge material is the exterior cladding material, the hole created by the pet palette will also be this material, while the operator's material can be set to the interior material, and inherited by the slab via SEO. Also, if a single operator is used to cut the holes in multiple slabs through the model for the stair, moving and modifying the operator will change all of these holes, where with the pet palette option all the holes would need to be edited individually (this might be more easily done with careful use of the multi-story marquee). Yes, SEOs do not change (or show) in the plan view.
HTH
‎2009-08-17 12:12 AM
‎2009-08-17 10:56 AM
tranthainguyen wrote:It's not about completing the task, but @ learning archicad
Can you attached the file you're trying?
Then I'll walk you thru'
cheers,
‎2009-08-17 11:23 AM
‎2009-08-17 01:56 PM
tranthainguyen wrote:I know about 2)cutting a normal hole in the slab,but i want a staight foward step by step method for 1)solid operation element.
Hi..
So then you might consider either:
1- Solid Operation Elements
2- Cut a normal hole in the slab.
Cheers
‎2009-08-17 02:36 PM
