cutting into mesh
I am wanting to integrate facilities into this hill. is there a way to cut to thru the mesh?
5 Replies 5
Djordje
Just like any other polygon ... select the mesh with the mesh tool active, draw the hole. Done.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
David Maudlin
lpbolden:
Or use what you are adding as the Operator of an SEO operation with the mesh as Target.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
i would go with a SEO also.. due to it(the mesh) being able to repair itself if u change your mind on whats going in the hole
what is SEO? i did a search in help but it didnt come up.
Dwight
"Solid Element Operation"
http://www.archicadwiki.com/Solid%20Element%20Operations
in geek: boolean
cut one with another, intersect and join....
Dwight Atkinson
