dhnguyen
demo wall and new wall
I have demo walls that are dashed. That layer is turned off. I'm drawing new wall on top of it. Wherever it intersects the dashed demo wall, it it shows up as being cut off. How do I get the new walls to show up as continuous? please see attached image.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
1 Solution
Each layer has an Intersection Priority Number.
If that number is the same then walls will trim each other even if one of the layers is turned off.
If the numbers are different then they will not trim each other.
If set as zero then even walls in the same layer will not trim.
You can save different IPNs in each layer combination, so wall can trim in one combination but not in another.
Go to post
dhnguyen
thank you, i changed them to 2 and that seems to do the trick for now.
DNguyen
ArchiCAD 18- 25
