2006-06-18 01:32 AM
2006-06-18 02:00 AM
2006-06-18 04:10 AM
Link wrote:Okay, and to redefine a saved and named view is "get current window's settings"
If you Show Organizer (top left button in the Navigator), and view it so that the Project Map is on the left and the View Map is on the right, you'll see a 'Save view>>>' button at the bottom. This will then appear in the View Map, at which point you can click on it and hit the 'Settings...' button at the bottom.
Not sure why you're jotting the name down, but you can do that there, as well as change all the view's settings!
Link.
2006-06-18 06:04 AM
2006-06-18 06:12 AM
Okay, and to redefine a saved and named view is "get current window's settings"No, you just change the settings right there in the View Settings dialog. No more work than before, just a different and more consistent way of doing it.
Much more work than before
As to your ?Yes a view needs to be named, it sounded like you were jotting it down on paper!
Why save a view if you don't know what it is?
I give each view a name so I can navigate back to it easily
2006-06-18 03:09 PM
Mike wrote:Why do they have to be renamed? Isn't that part of the purpose of a good folder structure?
Plan views of course will need to be re-named, but everything else picks up its name from the project map.
2006-06-19 12:22 AM
2006-06-19 06:31 AM
TomWaltz wrote:Can views pick up their names from the folder they are in? What have I been missing? Thanks for some pointers...Mike wrote:Why do they have to be renamed? Isn't that part of the purpose of a good folder structure?
Plans/Floor Plans/1/4"/1. First Floor
.... and so on....
2006-06-19 03:04 PM
Link wrote:The layouts are named for the name of the sheet.... do you mean how are the drawings named?
Tom,
Out of interest, how are you naming your layouts? And what are your titles for these views showing?
2006-06-20 12:00 AM
The layouts are named for the name of the sheet.... do you mean how are the drawings named?I was trying to determine how you create your drawings and layouts. You can place the entire Plans/Floor Plans/1/4"/ folder into your Layout Map, using the 'Place Drawing>>>' button, which will create individual layouts & drawings with the names 1. First Floor, 2. Second Floor, 3. Third Floor, 4. Fourth Floor, etc. Then the title...
We have long used a "drawing title" object that includes drawing number and drawing scale (automated) and a manual, multi-line title.The standard titles pick up the drawing names as above. In your case, you're using a manual title. It just seems there's a point at which the link is broken and all the good structuring and automation falls down. For you it seems to be between drawing names and titles, where you set the name manually. I've chosen to 'break the link' between the Project Map and the View Map, by renaming my views manually.
I never really got the flexibility and control I wanted out of Title Types, and I'm not overly impressed with the new Title Objects, but maybe that will change as I play with them more.I do remember that. Speaking of objects, have you or do you intend to update your sweet Interior Elevation marker for AC10?
