2004-12-20 11:29 PM
2004-12-20 11:37 PM
2004-12-21 04:19 PM
2004-12-21 05:43 PM
dobilan wrote:Unless I am misunderstanding you, create a view in your viewset of the floor plan with Display Options/ "Cover Fills" set to "No Fills" and a view in your viewset of your section with the Display Options/"Cover Fills" set to "Vectorial Hatching"
If I want to have different fills (for a wall for instance) in plan view and section what can I do? For example, for a brick wall I have to have no fill in plan view and a brick fill in section but I don't want to do this separating the section from the model, the section must be linked to the model. Can I do this?
2004-12-21 06:18 PM
Unless I am misunderstanding you, create a view in your viewset of the floor plan with Display Options/ "Cover Fills" set to "No Fills" and a view in your viewset of your section with the Display Options/"Cover Fills" set to "Vectorial Hatching"Well that'd be too easy Woody! Although I think it's the Cut Fills they want to set.
2004-12-21 06:24 PM
Link wrote:Well, Link... of course you're right. That's what I get for responding to ArchiCAD-Talk while talking on the phone giving tech support on another issue at the same time!
Link.
2004-12-21 09:44 PM
For example, for a brick wall I have to have no fill in plan view and a brick fill in section but I don't want to do this separating the section from the modelHere's another "trick". Duplicate your brick fill (so that you don't trash it trying this), and completely clear the bitmap preview image for the original (used by your walls) to be all white.
