different materials for the same wall.
Hello all,
i m new to this site.
i've just started learning achicad and have a prob.
in my buillding, i've got a long wall what i want it to get different materials.
i don't know how to do this.
could anyone give me a hand.
Thanks alot for ur help
6 Replies 6
vfrontiers
ar_raneem wrote:
Hello all,
Split the wall into pieces where the materials break. Often, it is a good idea to have different walls (or different composite walls) where materials change. Then you can allocate space in plan for items such as STONE VENEEERS, etc.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
thanks alot.
i was thanking about this solution but i was woundering if there is any others.
thanks again dear
You don't specify if you want different materials horizontal or vertically.
Duanes advice above applies more to vertical divisions in a wall (although you could break a wall down into horizontal parts if you wanted, but there is a better & easier way to do that).
For different materials horizontally you should consider using a complex profile assigned to a wall. You can individually split the wall into any number of components, apply a different material to each, and extrude everything along the whole length.
See this tech tip for an example - http://www.archicadwiki.com/TechNotes/Changing%20Materials%20of%20Complex%20Profile%20Walls
ar_raneem, you've mentioned a long wall.
i think you can set the walls to different priority.
so they can not touch each other.
and you may set the material individually
The walls should work just fine without having to touch the priorities. They are in a straight line so no joining is occuring anyway.
Thank you very much guys.
i did appreciate ur help
now i can change my walls the way i want.
thanks again
