discrepancy between the shadows of Revit and ArchiCAD!
I tried exporting my 3D model to Revit and tested the shadow study there, to my surprise there is a discrepancy between the shadows of Revit and ArchiCAD!
see the red line showing the extent of the shadow..
The settings seem identical, same city (same azimuth & altitude) same date (march 21 at 12pm) and they are both using the same model, 0.00 is at the same level.
Shouldn’t they be identical??
PS I dont think it is a daylight savings time issue, since the problem is not in the Azimut of the sun but in its altitude.
7 Replies 7
The azimuth is a bit different too, check out the right side of the funky shaped home near the center of the drawing.
I think I once read some Wiki article or something about the method ArchiCAD uses for its shadow studies.
I found the wiki article here http://www.archicadwiki.com/TechNotes/Sun_Study_Accuracy?highlight=%28shadow%29
but my discrepancy seems much bigger than that. (mine seems to be a 12m. discrepancy also in a 100m. tall tower)
Very interested to hear the resolution of this issue!
Have you tried the same model in SketchUp and Artlantis? I would hope we would not see 4 different solutions...
Thanks,
Karl
Perhaps I posted before testing enough, I just started from scratch with a simple test model and the shadows are identical between software. (see image)
So I’m still not sure what setting I had wrong that was causing this..
Dwight
That error would be the exact direction of North, were i betting.
Dwight Atkinson
As usual you are right Dwight! My project north is different; also daylight savings time was not set which I thought is automatic..
(Both settings I don’t know how to change in Revit, but rotating the whole model and using 11:00am instead of 12:00pm did the trick)
I guess the moral of all this is that we can be confident that the shadows done in ArchiCAD are accurate..
Dwight
As accurate as in Revit, at any rate.
Dwight Atkinson
