Another vote for the mesh, of course...
But, another workaround if you're otherwise happy with the slabs as they are at the moment is to select all of the slabs and right-click to convert them to morphs.  Then, with all of the morph-slabs selected (undo-redo), right-click and Boolean Union them - to create a single morph.  All of the contour lines will now show if the morph floor plan display is set to outlines only.
If you have to adjust the slab sizes now that the mass is a single Morph, just use the push-pull pet palette option on slab edges.
In the future, the mesh really isn't that challenging... if the original survey contours are not continuous, you'll trace over them with linework that you later magic wand into mesh contours and elevate.
The mesh will of course be smooth like reality.. and your slab approach will look like a cardboard model... and the cardboard look might have been what you were after anyway...
