display text in objects mirrored
Is there a way to get the display text in AC 9 Library standard objects to remain in the same angle when the object is mirrored or rotated? (specifically when used part of a hotlinked module) (see attached image)
"Adjust angle of fixed-angle elements to reflect module rotation" in the Module Settings doesn't seem to do that.
undefined
TomWaltz
Unfortunately that setting only applies to actual text placed with the Text Tool, not text inside objects. If the programmer of an object is any good, there is an option to do that within the object. In this case there is not....
Tom Waltz
thanks Tom
