SOLVED!
door concealed by beam underneath slab
hello, the door at 0.00 above slab is concealed by the beam under the slab, why please, thanks
1 ACCEPTED SOLUTION
Solution
Hello emailcopy,
You can make the hatch background of the beam transparent .
You can change the display order of these elements (right clic on the wall with the door).
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
2 REPLIES 2
Solution
Hello emailcopy,
Christophe - FRANCE
Done, many thanks Christophe
