door concealed by beam underneath slab
hello, the door at 0.00 above slab is concealed by the beam under the slab, why please, thanks
Hello emailcopy,
You can make the hatch background of the beam transparent .
You can change the display order of these elements (right clic on the wall with the door).
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 13 Ventura - MacBook Pro M2 max- 32Go RAM
Hello emailcopy,
Christophe - FRANCE
Done, many thanks Christophe
