Eric Milberger
doors do not cut thru wall
The wall is 4: thick  the door does not cut through the wall  and it should set within the wall.  I had to thidken hte wall wo wee the door frame  not good if wall still shows
Eric Milberger, Architect | Master Planner
4 Replies 4
Is there more than one wall there?
i.e. the door is in one wall but a second wall is showing through?
Guru
Check the Renovation Status of the involved elements.
Eric Milberger
nope, one wall
Just to be sure the doors are in the wall we see (and it isn't a renovation status thing as mentioned by Lingwisyer) - vs attached to a foundation wall, but at this elevation ... while you're in 3D, just drag that wall away somewhere (and undo afterwards).  Do the doors move with the wall?
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
