drawing in 2D
This is probably a silly question, but here goes:
How do you draw a 20'-0" length of wall using the wall tool? Or any length of line or wall for that matter. In Revit, you just select the wall tool, click the start point, drag in the direction you want the wall to go and then simply type in the length. But with ArchiCad it isn't that simple and I have searched and searched to no avail. Or maybe it's easier and i'm just missing it.
Please help.
Thanks.
7 REPLIES 7
There are several ways to do this depending on the circumstances.
The simplest and most common is to start drawing the wall in the desired direction (using guides, constrains, snaps, or whatever) and then typing the length in the Tracker. If your Tracker is not showing you can make it appear by hitting the "j" key.
Ummm... it is that simple. Somehow, you have turned off the 'Tracker' (search the help file), and probably the Guidelines too.
As soon as you click on the start point and start moving the mouse away (released the button), the tracker should follow your mouse, waiting for you to simply type the length.
NEVER read the length and click. It will NOT be correct. I.e., if you see 10' in the tracker and click, you will be at something that rounds to 10 feet, not necessarily at 10 feet. You must actually type the 10.
Do note, since you are new, that you never have to type the ' or " symbols for feet or inches. See the help and training materials. A number without a symbol is feet. Numbers with a dash (minus) in between signify feet and inches. So, 3-6 is 3'-6". And finally the slash substitutes for the ", so you do not have to use the shift key. 5/ is the same as 5".
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Just to be extra clear, this assumes the working units are set to feet and fractional inches. Other settings behave similarly but not quite the same. (Metric of course is stone simple.)
yup you have deffiantly turned your tracker off
options>work environment>tracker
mine turns its self off all the time is there a quick key for it that i must be accedently hitting to turn it off?
The self-canceling Tracker is definitely an annoying bug. The quick toggle (by default anyway) is the "j" key (no modifiers).
Thanks guys. Honestly, I looked through help and everything. It's just such a simple thing and is probably just set up on right most that the "help" options didn't have a solution that i could find. But mine was probably just turned off then. I'll check tomorrow. Thanks again.
Thanks for that, Matthew. Bedrich7 says he is in Salt Lake City, so I just assumed he was working in Imperial as a new user... That assumption might have confused a bunch of other people!
