duplicated window / weirdness with frame
i have a window set just right. i duplicate it, dragging it over a few feet along the same wall and something weird happens to the frame.
it jumps out of the casing or flips where the top window of the double hung is then on the bottom or reversed or something.
whats up?
2 Replies 2
Erika Epstein
Not enough information.
Which window?
Is it a custom profile wall?
A screen shot might also help.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
this is the weirdest thing.
In short, for whatever reason, the new windows, are offset outside of the wall for whatever reason. this is driving me nuts!
if i even open the properties of the lower window then hit ok and close the properties, without changing anything, it pops out like the top one.
the transom was correct, except i need to change the size and number of sashes. changed those items in the properties and the frame (or whatever that is) pops out. i can not get it to go back. maybe i dont know what setting to actually change.
this also happens sometimes when i simply duplicate a window and drag a copy over a bit on the same wall.
