elevation missing lines of profiler object
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-08-29
11:12 PM
2023-05-23
05:13 PM
Rubia Torres
2006-08-29
11:12 PM
I am assuming this could easily be modeled with AC 10's slanted walls, the curved glass wall would be segmented into straight segments. is that the way it would be done with 10?
p.s. the reason I didn't use the curtain wall curved object is I need more control over the profile..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-31 07:41 AM
2006-08-31
07:41 AM
As a first step, you can install the latest AC9 Hotfix (2219) and see if that makes any difference.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-31 02:41 PM
2006-08-31
02:41 PM
Hassanen:
It looks like the glass runs through the mullions (in your 3D View I can see the edge of the glass at the side of the end mullion), so ArchiCAD does not recognize an intersection (the glass and mullion occupy the same space). I am not sure how you created this object using the Profiler, but you might try creating the glass and mullions as separate parts, then using SEO to subtract the glass from the mullions.
HTH
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-08-31 03:45 PM
2006-08-31
03:45 PM
David wrote:yes, that solved the issue quite effortlessly, since I had the glass as one object and the mullions as another! thanks David
the glass and mullion occupy the same space... using SEO to subtract the glass from the mullions.
I haven't checked for updates for a while, thanks for the tip Laszlo.
