empty opening with arched top and slanted reveal
Hello!
I am modelin one gothic fortress for renovation purposes.
So every opening are as described in topic title.
So how to get that without having window in 3d?
I know how to get it in 2d. I use classic windows and in model view options turn off windows. Is there that option for 3d?
or is there some custom empty opening?
here is the fortress I have to model:
http://www.webdesign.elstro.hr/wp-content/gallery/gradevine/garic-grad.jpg
here is a movie:
http://www.youtube.com/watch?v=lm4cwuudy_g
I have to model only the main building.
please help me. it is urgent.
20 Replies 20
Please see Olivier Dentan's Reveal SEO on his web site.
It may be what you are looking for.
http://archilib.od.pagesperso-orange.fr/
Peter Devlin
Peter Devlin
I found solution with openings in window library, but will try with this.
thank you.
few moments noticed that this openings has a lot of bugs.
when set it to what I need I got this:
Is there anything better that this?
I have tryed Dentan's reveal SEO but it is way too limiting. I can't set depth of it.
Check this article:
http://www.archicadwiki.com/CreateCustomWindows
Based on this you can model those Windows out of profiled walls and saved them as Windows. Setting the proper IDs is very important for it to work.
laszlonagy wrote:
Check this article:
hm, but my profile is changing along the axis (through the depth of the wall).
Is it constantly changing or there are two or more different profiles in it?
Sorry I can't figure it out from the image you attached previously.
here is new illustration. first are the setting of the opening that I need. and which caused the problem shown on previous picture.
below is that opening modeled with shell tool, which is useless since I can't substract it from wall.
I have problems with uploading picture to the site.here is fileserve link:
http://www.fileserve.com/file/U9GaKFr/opening_2.jpg
Hi mzex,
Could you put it on the web on some other site?
I don't want to install that downloader program just to be able to look at this one image.
You may also try to zip the jpg and attach that to your post.
