error in object : Skylight !?
hello everytime i try to make a skylight i get this error please help me what should i do and where can i download the skylight again cause i cant find it??
its a msg written : fill not found ! at line 59 in the 3D script of file skylight pyramid14.gsm and i've tried them all and it gets me the same msg?
any ideas?
2 REPLIES 2
David Maudlin
xpepsigirl:
Your problem is similar to the one discussed in this thread:
Library Parts Not Working Properly
You need to go through the skylight's parameters to find the missing fill and select one that is part of your PLN file.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
thank you 😃
I wish i can apply and work at the united states, am an architect in kuwait
