extrange behavior on archicad wall settings tool bar
Hi , i have been experimenting something rare in archicad 11, when i select a wall ( with arrow tool ) , some times the wall settings menu tool bar it doesnt appears on top display , when i select the wall on any of his vertices or intersections the wall settings menu appears on the display and let me edit the wall , but if i select the wall on any of their edges ,the wall settings menu it doesnt appears on display , hopefully somebody help me to clarify this
thanks
thanks
i have to mention , this behavior , begins afther i activate the maxwell render option on archicad 11 , afther a long time this rendering engine had been disabled , a dont know if this situation could be a cause of this problem functionality
thanks
Sounds like it might be related to something that was mentioned here.
http://archicad-talk.graphisoft.com/viewtopic.php?p=128826&highlight=trace#128826
Try turning off your trace reference.
Don't just turn off the trace dialogue window, you have to turn of the actual trace reference.
Hi Barry , yes it sound same like me problem , ill try to do what you mention here , and hopefully the problem has gone, because as somebody said here it is imposible to work on this circumstances
thanks
