‎2009-03-08 09:37 PM
‎2009-03-08 10:44 PM
‎2009-03-11 08:34 AM
‎2009-03-11 04:48 PM
kombibob wrote:You can make vertical alternation by splitting the wall into segments of different profiles. Depending on what you want the curtain wall tool may do the trick as well.
in complex profiles, you can even have one fill type with varying material finishes... This has worked well for me on occassion, although it is limited to horizontal layering of materials.
