fill origin
I have a siding pattern on wall in my elevation that I'd like to change the fill origin of. I need the pattern to start at the end of the wall, right now it seems to be centered on it. I can't figure out how to change this. help? thanks.
Djordje
View the walls in the 3D window. Select the walls. Choose Edit/Align 3D texture. It also aligns the fill associated with the texture.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
In certain cases setting different direction just not works when "Parallel View" is on > in perspective mode never a problem.
Changing origin works in both.
Didn't know the fill is changing too. Nice
