filleting an arc and a line
I can fillet two lines, but I can't fillet an arc and a line or two arcs
12 Replies 12
I have wished AC could do this too (it can't). You should add this one to the wish list
Select the arc and line. Use the intersect tool or trim the ends so both endpoints meet. Activate any tool except the arrow tool, click on the corner. Pet palette pops up, select the fillet option.
Aussie John
WOW tip of the year
Cheers John
[/size]
VERY COOL ALEX! Definitely tip o' the month material.
Dwight
And I nominate this discovery for "Most-Annoying-Just-Waiting-To-Be-Discovered-Eureka-Moment-of-All-ArchiCAD-Time." We should call it the "Mouse Quiver of the Century" describing the erotic and joyful pulse of amazement that travels up the arm when the discovery actually works. My arm, anyways.
Dwight Atkinson
Way to go, Alex! What other treasures lie hidden.... 😉
Off topic (lines only here - not arcs), but same pet palette: if you do the same thing to two lines, you get the Fillet/Chamfer Radius dialog - but there isn't a means to select which of fillet or chamfer you want ... you just get a fillet (matching the pet palette icon). It looks like GS simply used the same input dialog as for Line Extras ... and that the implication of Chamfer in the dialog is a cosmetic error. But, maybe I'm missing something?
Thanks,
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Dave Jochum
You can also have the arrow tool activated and select the last option in the pet pallette (switches from transformation to modification), then select the fillet option.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
Dwight
Okay - Mouse Quiver "Corollary Tipette"
Dwight Atkinson
Djordje
Gone to Tips&tricks, of course ... hope he has the sun deck for all the chairs 😉
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
