ā2009-04-06
08:10 AM
ā2023-05-23
03:04 PM
Rubia Torres
ā2009-04-07 05:54 PM
ā2009-04-07 07:12 PM
lec1212 wrote:Complete collapse? And this was modelled just to restore the facade. I wonder if the guys who built it back in the 16th century thought about lateral movement? Oh well, I guess they can't be sued anymore...
Also looks like your model has what we call "soft story" issues. complete collapse from any lateral movement, based on the bottom floor.
lec1212 wrote:The image was intended to illustrate the level of complexity it is capable of handling - anything simpler is, well.. simpler to model.
What we have lots and lots of in the US is what we call conventional light frame construction. How will Framewright handle this kind of framing?
lec1212 wrote:I've attached a smattering of images that I had close to hand. This software is capable of modelling any kind of framing, but the design methodology and tools will suit some better than others. Time varies with complexity, but from start to completed quote/scheduling is typically between 1/2 to 2 days. We offer a demo, so you could try it for yourself. I can put you in touch with other users too.
Can you show a more conventional framing? Especially with split story
and hip roofs? Two very popular design concepts here.
Also at least somewhat on a sloped lot with stepped foundation.
Maybe even a split wall dormer. That's where the dormer sits down into a pocket of the wall framing part way, ie does not sit on the roof, per say.
Relative easy of doing this type of framing? Time it takes?
ā2009-04-07 09:27 PM
ā2009-04-08 12:45 AM
lec1212 wrote:
Hi Ralph
Although very fancy indeed, not very practical, at least here for most framing.
Two things:
1. What we have lots and lots of in the US is what we call conventional light frame construction. How will Framewright handle this kind of framing?
2. Also looks like your model has what we call "soft story" issues.
Thanks
ā2009-04-08 05:39 AM
