Llian
foundation footing to wall
i tired wall but it automatically joined to the foundation wall,then i used slab but the corner doesn't joined, i place an inverted beam object and the length is not parametric.......can someone here tell me where in the manual provide that kind of help?
i must be so spoilt with revit 2011 that surprisingly alot friendlier for dummy like myself!
i've been in working so hard to re-learn but the last 96 hours have been painful....is disappointing ....i am not sure where went wrong but i surely had a very good expereince with 4.5 in '94 without much internet help but got to do some good stuff within couple of days....
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
3 Replies 3
Llian
here's the object settings ..strangely the parametric is on the width but not on the length??? am i missing something here?
Llian
attached here is the option showing the 'height' grey out..the section picture is correct to 24" footing with 8" wall, projection and thickness but I can't have the lenght/height adjustable.....does anyone has other suggestion how to have this very simple footing ? it' can't be that complicated with smart archicad ??
Please see the attached image. You can also try with a complex profile assigned to a beam or a wall.
