2008-09-23
08:55 AM
2023-05-25
05:51 PM
Rubia Torres
2008-09-24 01:18 AM
2008-09-24 01:47 AM
jbArch wrote:yup thats what i tried to do.. file>libraries and objects>save modle as
For the slab method, view it in 3d (from what will be the "top") and then use "Save Model As..." in the File menu.
jbArch wrote:even when i click on beam.. what then??? all the buttons are blanked out and im un able to click anything to save or store it??
For complex profiles I think you are almost there. In your profile manager you have it set to use with walls, but you need to use with beams instead. Just click on the beam option (there are 3 icons: one for walls, one for beams, one for columns).
2008-09-24 01:57 AM
2008-09-24 02:04 AM
saving as GSM is fine...cheers, ill give that a go
2008-09-24 02:33 AM
2008-09-24 05:42 AM
2008-09-24 06:05 AM
Erika wrote:cheers. yeah iv been looking at that, and have seen it mentioned a few time in various thread.. just gotta convince the boss to spend the moneey to buy it
Nice work!
You might want to take a look at Ralph Wessel's Objective
http://www.encina.co.uk/objective.html
There's a free 30 day trial that is well worth doing.
2008-09-24 06:21 AM
2008-09-24 07:08 AM
2008-09-24 07:25 AM
GeNOS wrote:This is what you want (see image)
the way i did do it was with the complex profile. im just playing with saving it out as a library item.
im in 3d with the parallel projection settings window open and i have x and z on zero degrees, and Y on 90 degrees.. this gives me a top/plan view of the slab laying flat.. i need to set Y to zero to get the actual "top view" of the gable tim before saving it out.. but every time i type zero in to the Y it just jumps back to 90...?? the closes it will alow me to 0 degrees is 0.5 degrees? any reason i cant get it to go to exactly zero?
or am i meant to be somewhere else to be setting the camera angle???
