globally replace materials ???
Hi
I have a large model and I want to globally replace all materials with a single material.
Any way to do this?
TIA
Adri
5 Replies 5
TomWaltz
So you basically want to make the whole building something like "foam white" or "balsa wood"?
Tom Waltz
exactly...
Any way to do this?
I've played about with aat files and so far can't see how to do it...
TIA
Adri
Fran_ois Chatelain
Hi Adri,
save the entire model as an object and then apply a single material to the object. Don't forget to uncheck the "Use object material" tickbox.
Hope this helps.
Cheers
François
François Chatelain
Worldwide Digital Imaging
Formerly posting as RanXerox
"A little bump will help blur your reflections"
Doh, thanks for the tip, never thought of that, so simple
Link
If you wanted to keep your model as ArchiCAD elements, you may be able to gain something from this Global Material Change Tip.
Link.
