go to the element in Plan view by selection in 3D view
dhaval7shah
while selecting something in 3D view window, how can we detect or call that on the plan view ? i know this is not possible straight way, but is there any trick someone already found?
Dhaval Shah
Upto AC 22
iMacs and MacBookPros: Mac OS X (10.6 to 10.12, Intel core 2 Quad to i5, i7, 8 GB to 16GB)
Win 10, AMD Opteron 6-Core x 2, 16GB, FirePro W4100 2GB
& ThinkPad E550
& i7, 8GB
7 REPLIES 7
dhaval7shah
while trying just got the solution,
> open the 'selection' palette from 'window' menu,
> select the element(s) from the 3D view window,
> using 'selection' palette, store the selection with a name,
> come to the plan view and activate the stored selection.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
Steve Jepson
Good question. You can lock what you have selected in the 3d view.
Then press F2. The locked objects will have a different node color.
This us useless if you already have some things locked.
dhaval7shah
thanks Steve.
This function should be in the wish list for sure.
If selected objects are in the common (same) story, then there should come an option in the 'right click menu' to see the objects in plan.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
This is a good idea.
However, I see there are complications.
E.g. if several elements are selected in 3D and their Home Stories are not the same, then which Story should the command take you to? The Home Story of the last selected element?
Or should the command work only when one element is selected or all selected elements have the same Home Story?
Still, I think you should make a wish for this, would be a useful feature.
dhaval7shah
I hope the interface could be programmed such a way that
> if the selected elements are from one and common story, then there should come an option in the 'right click menu' to see the objects in plan.
> if the selected elements are from more than one stories, then there should come more options in the 'right click menu' to....
. > see the objects in 0 story,
. > see the objects in 1 story,
. > see the objects in 2 story.... like this
This story option list should automatically come in the menu, as per the selected objects home stories.
Thanks for your appreciation, I already added this wish today, and now i will also elaborate that with the texts above.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
I think it is good idea to see in a plan window, what have we really selected.
Objects, that are not belong to current story can be shown as a special ghost
with some different color, lets say light-green or with a running dashed linetype.
And right click is not needed.
dhaval7shah
http://archicad-talk.graphisoft.com/viewtopic.php?p=187914&sid=fff563932396bcfe9f2849958d11b61e
Please vote, thanks.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
