grouping walls
hello
I want to know pls if I can creat a "grouped" wall for example...
I mean...when I draw the wall it comes segmented...then I am finding myself
grouping it....is there a way to fix it beforehand?
thanx
1 REPLY 1
Turn "Autogrouping" on.
Edit menu > Grouping > Autogroup.
Then anything you model with the one single command will become a group.
Make sure you have grouping "Enabled" so you can select the group all at once.
