2013-08-03
01:06 PM
2023-05-23
02:35 PM
Rubia Torres
2013-08-03 02:03 PM
2013-08-03 02:12 PM
Kamelite wrote:With all the elements showing, select a wall that disappears and check its layer assignment. It seems like some elements have been assigned to the wrong layer. Then follow JLopes's advice.
I can't think of any specific layer that would turn off just a few walls like that.
2013-08-03 02:59 PM
2013-08-03 04:35 PM
David wrote:As always, you guys are right. Somehow I managed to define the walls that disappeared as interior walls, and ofcourse they don't show in an elevation. That also explains why the showed after I turned on every layer.Kamelite wrote:With all the elements showing, select a wall that disappears and check its layer assignment. It seems like some elements have been assigned to the wrong layer. Then follow JLopes's advice.
David
2013-08-03 07:34 PM
