2010-08-06
09:40 PM
2023-05-23
06:07 PM
Rubia Torres
2010-08-11 11:43 PM
lec1212 wrote:Don't have a lot of time right now, but maybe this will work:Richard wrote:Hi Richard
Another possibility is to use the Trussmaker tool to create a railing. This is actually pretty fast, and can be modified later.
I've only used Trussmaker for one small job so far, so if you don't mind could you post an image that might explain how this works for you?
Thanks
lec
2010-08-12 07:03 AM
jocontreras wrote:Hi jocontreras
Hi jocontreras
1. How's it's interface/blending with raked to flat areas? it does a good job
2. How well does it handle curved stairs that flare out wider gradually from top to bottom. ie. Top is say 3' at the bottom 5'. ]sorry no curves you can use curve railing from archicad And try to match the design with multirail 2
Any other specific insights would be nice. The library part is pretty flexible laying out custom pattern od balausters and paralel intermediate bars but IT CANNOT HANDLE ALL INSTANCES inclinations and mittering is prettty good
Thanks
lec
2010-08-12 07:06 AM
Richard wrote:Hi Richard.lec1212 wrote:Don't have a lot of time right now, but maybe this will work:Richard wrote:Hi Richard
Thanks
lechttp://www.graphisoft.com/support/archicad/archiguide/techtipsept2002.html
2010-08-12 02:46 PM
2010-08-12 03:45 PM
