handrails of stairs and rails library do not match perfect
Where can I find more independent types of railings, outside of the library offers so fits perfectly with all settings handrails of stairs? I searched railings so I set them to match the scale of (or change them on the scale of those that fit the library).
I did not really, as you can see in pictures.
Of course, I need railings and curved out what is in the Library program.
14 Replies 14
lec1212 wrote:
Richard wrote:
Another possibility is to use the Trussmaker tool to create a railing. This is actually pretty fast, and can be modified later.
Hi Richard
I've only used Trussmaker for one small job so far, so if you don't mind could you post an image that might explain how this works for you?
Thanks
lec
Don't have a lot of time right now, but maybe this will work: http://www.graphisoft.com/support/archicad/archiguide/techtipsept2002.html
Richard
AC26 (since AC6.0), Win10
jocontreras wrote:
Hi jocontreras
1. How's it's interface/blending with raked to flat areas? it does a good job
2. How well does it handle curved stairs that flare out wider gradually from top to bottom. ie. Top is say 3' at the bottom 5'. ]sorry no curves you can use curve railing from archicad And try to match the design with multirail 2
Any other specific insights would be nice. The library part is pretty flexible laying out custom pattern od balausters and paralel intermediate bars but IT CANNOT HANDLE ALL INSTANCES inclinations and mittering is prettty good
Thanks
lec
Hi jocontreras
Thanks for the reply.
For now I think the no curves is a deal breaker for me, as I've been learning Objective and It creates curved stringers/railings very easily and splayed/(spreading) from top to bottom real nice if need be.
But maybe multirail-2 would be nice for some other things.
I'll see if they have a demo.
Take care.
Be safe out there.
lec
Richard wrote:
lec1212 wrote:
Hi Richard
Thanks
lec
Hi Richard.
Printed it out and will try soon.
Take care.
Be safe out there.
lec
If you can buy objective this is the way to go. No need for multirail 2
In fact Im saving money so I could buy it soon.
Its sad this great program (or something similar) is not included on archicad package (maybe on version 15 )
KeesW
Cadimage's Stairbuilder should do it. I've always found their draftmanship imaculate. Free or low cost for students, also 30 day free trial versions. Google them for info!
Cornelis (Kees) Wegman
cornelis wegman architects
AC 5 - 26 Dell XPS 8940 Win 10 16GB 1TB SSD 2TB HD RTX 3070 GPU
Laptop: AC 24 - 26 Win 10 16GB 1TB SSD RTX 3070 GPU
