hiden object mekes holes
Hello all
Can somebody help me?
The problem I have faced is next.
When some object is crosed with the wall is macking a hole when is hiden in hiden layer. See attached pictures. How to avoid such holes?
Thanks in advance
vistasp
Welcome to the forum, RoLand. You need to read up on element intersection and building material priority.
Basically, the (black) frame of the shutter (?) has a higher priority than the brickwork. When multiple elements occupy the same space, the ones with lower priority are automatically cut away.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Hi dear
Thanks for hint. now it is solved.
Have a great day!!!
