hiden object mekes holes
Hello all
Can somebody help me?
The problem I have faced is next.
When some object is crosed with the wall is macking a hole when is hiden in hiden layer. See attached pictures. How to avoid such holes?
Thanks in advance
2 Replies 2
vistasp
Welcome to the forum, RoLand. You need to read up on element intersection and building material priority.
Basically, the (black) frame of the shutter (?) has a higher priority than the brickwork. When multiple elements occupy the same space, the ones with lower priority are automatically cut away.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Hi dear
Thanks for hint. now it is solved.
Have a great day!!!
