how i can custom railing that will be used on curve path
hello every one i want to create railing that are going to be used on path like curved it is not straight it is like fence or something but how
in revit it is easy to create it using railing how about my lovely programme archicad please i need to know and thanks
6 REPLIES 6
vistasp
A complex profile is great for something like this. If you need to incline it, make it a beam.
http://www.archicadwiki.com/Creative%20Uses%20of%20Complex%20Profiles
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
beam can not produce curve plan from top as i tried it
A complex profile wall can but you can't slope a wall.
vistasp
Oops! Didn't read the question properly.
= v i s t a s p =
bT Square Peg
The add-on Objective works well, but in a pinch I have used the roof tool to make a curving rail.
Just draw the curved shape in plan and use that for the outline of your railing (magic wand the outline). It's not entirely accurate, but for a quick rendering for a client it works ok.
The roof tool allows you to also angle the edges.
what about archistair (under cigraph addon) it allows you to create custom railing this i discoverd it just this moment from their pdf help document here is image ? did any one tried archistair also
