how to change keyboard shortcuts commands
i want to know when i press enter it is mean ok for the command i want to change it from enter to space so space mean ok how can i do this (i think maybe it is in work environment -- keyboardshortcut -- then what that is the question ?)
Thank you
7 REPLIES 7
That is one of the commands that you cannot change in the Work Environment, as Enter is the standard default button (usually "OK") key for both Windows and Mac OS.
If I may ask: why do you want to use the spacebar for this function?
Eduardo Rolon
Karl, in Autocad the spacebar is enter so I am guessing that might be the reason.
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
i want to change ok shortcut keboard from enter into space and in the mean time it can preserve magic wand shortcut the important thing how can i change from enter to space
Eduardo Rolon
Ahmed,
You already asked this and the answer was that it cannot be done. Why are you asking about it again?
AC28 US/INT -> AC08
another Moderator
Because i am familiar with autocad environment it is really hard and noisy to press line then enter i am trying to adapt myself but i was hoping if there is a way
Eduardo Rolon
First in AC you don't have to select line then press enter, that is not necessary and in fact I have no idea were you are you need to press enter. If it is in dialogue boxes pressing the spacebar or pressing enter should make the same amount of noise.
If the problem is with the polyline tool or polywalls then clicking again in the last node finishes the command no need to look for enter.
AC28 US/INT -> AC08
another Moderator
you are right thank you cheers and more regards to your respond
