how to create a "block"?
For example, I draw a floor plan and copy this several times. Now I will edit this floorplan. Its possible I am editing just one floor plan and the other copys of it changing automatically ? Thanks, Jens
1 REPLY 1
Hello Jens
It is a job for the modules…
You can see in the two links that follow some examples. http://www.graphisoft.com/community/envisions/2004.01.dormermodule.html
http://www.graphisoft.com/support/archicad/archiguide/multistoryhotlinks.html
You just draw one floor plan, save it in modules, place the copys in the good place, change the original one, update the links and the other are update too.
Hope this helps…
