how to create walls
i'm new in archicad, and i want to know how to create walls like in the picture
6 REPLIES 6
Erika Epstein
Draw your walls and then with the roof tool create a roof that will be used to trim the wall to the desired shapes.
If you use the trim-to-roof techinique you can delete the roofs.
If you use the solid elements operation technique put your roofs on a layer that can be turned off (SEO layer).
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
hmm.. so then how can i create roof so wavy?
The roof tool has a geometry method for making curved roofs (segments along a curve really). It is s little tricky at first but pretty easy once you get the hang of it.
Dwight
The answer to your question is on page 146 (or so) of the Reference Guide "Drawing Barrel Vault Roofs"
Dwight Atkinson
Jere
Completely off-topic, but Dwight, that's the greatest mosue pointer/cursor you've got there.
ArchiCAD 26; Windows 11; Intel i7-10700KF; 64GB RAM, GeForce GTX 3060
Dwight
I keep losing the tiny arrow-thingy.
"PinPoint" is the application for the target pointer.
Dwight Atkinson
