‎2008-12-10
07:27 PM
‎2023-05-23
03:06 PM
Rubia Torres
‎2008-12-11 06:56 AM
GeNOS wrote:Indeed, the same behavior here. Very intriguing. I don't know if Graphisoft is aware of this, but it's good to know there are workarounds.
if you draw 1/2 of teh line work then mirror it over to make it symmetrical, then any archs or circles mirrored will cause the error.. if you mirror just the lines and copy the circles over and trim them up (no mirroring of archs or circle) then it works fine
‎2008-12-11 07:28 AM
‎2008-12-12 12:31 PM
‎2008-12-12 04:30 PM
Peter wrote:did that and tried all sorts of SEO operation but none was working. i drew the roof line as lines, used the trussmaker and safed the object as gdl. afterwards i put the gableline object ontop of the wall and tried the SEO operations. wall as target and trussmaker ine object as operator. there must be something wrong in the way i did it? can anyone tell what, and what i could do to make it work?
The dutch gable wall can be made by making the gable shape
using TrussMaker and using it to SEO with upwards extrusion
a normal wall as target.
Peter Devlin
‎2008-12-12 04:47 PM
‎2008-12-21 07:12 PM
‎2008-12-21 07:52 PM
‎2008-12-22 12:03 AM
babs_80 wrote:
thanks to everyone for your advice. i finally managed : )
now i am about to deal with another upcoming problem. i drew the windows with the ceiling tool, and saved them afterwards as window- object. all worked fine but in the 3D perspective the openings in the walls are square, while the windows are arched windows, as to be seen in the attached pic.
what do i have to do in order to get the walls just cut where the actual windows are?
thanks a lot guys.
