how to get smooth arcs
I'm new to AC.
I'd like advice on how to get an arc drawn with the arc/circle tool to be smooth, not segmented or rough. Is there a setting for this tool to do that?
Thanks for any help.
10 Replies 10
What, no takers? This is your chance to show your superior knowledge.
TomWaltz
The arc tool does that on it's own. There's nothing to tell.
Tom Waltz
Doug wrote:
I'm new to AC.
Are you using the arc/circle tool (which always draws round curves, not segments) or are you magic wanding a curve in place?
The magic wand has settings for smooth curves or best fit line segments.
__archiben
Tools>Magic Wand Settings...
~/archiben
b e n _ f r o s t
OK, my confusion. I was trying to do something that's really outside the scope of this forum (and over my head) that ended up looking unsmooth.
Sorry to bother you with it. I'll stick to legit concerns from now on.
Djordje
What did you try to do?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Haneef Tayob
I would also regard the arcs that AC produces as being reasonably smooth.
I recall that Autocad used to have a 'viewres' setting to control the level of arc resolution. With current technology this resource saving item (speed vs image quality compromise) has probably been done away with. The arcs that ArchiCad create should really not be showing up as octagons or other polygons.
Is it possibly a video card problem?
Check and play around with the '2-d redraw options' under 'work environment'
If you're not having any joy, post a sample image of the problem.
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
I tried copying and pasting an arc from AC9 to Photoshop to produce marketing graphics. It looks jaggedy in Photoshop, which made me think it wasn't smooth. Frankly, I know even less about PS than AC, so it might actually be smooth.
I might just spend the money for a graphics drawing program (I'm looking at Intaglio for the Mac) for that kind of thing.
Again, thanks for the input, and you can consider this topic closed if you want.
TomWaltz
Generally you cannot copy something graphic from Archicad into another program.
You either need to export it through the Publisher system or print to PDF.
Tom Waltz
