how to let morph object to show on one same level/Floor plan
I have built a bridge with morph tool and i'm trying to get them show on the same level/floor plan, i think because it's so tall so it got cut off, i've tried to adjust the stories setting, still only show some parts of it... please help!!
Forgive me with the English... English isn't my best. thank you!
5 Replies 5
David Maudlin
JimiWCL:
It is a bit difficult to understand what you want to achieve (screen shots would help), but you can try changing the Morph's Floor Plan and Section > Floor Plan Display to Outlines Only or Overhead All.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Two things come to mind off the top of my head...
1. Make the overhead line type of the bridge morph match the plan symbol line type.
Or...
2. Set the cut plane above the bridge.
I'm not sure if either of these would do what you need.
Another possibility is to model the bridge along with the overall site in a separate file with no overhead stories.
This is my bridge on the ground floor plan, some bits are missing they're on different stories. Is there a way i can get them all on the same story? and the Morph is cut in half and shows on different stories as well. I can't work it out.
David Maudlin
Jimi:
See attached image for display settings to try. The story setting is also shown. You can use the Morph Boolean Operations > Union command to combine Morphs.
Thanks for adding the signature.
David
David:
I have tried the story setting, nothing got changed until I used the "Morph Boolean Operations", and it worked!! even though I still can't move them on to different stories.
Thank you very much!
I was very frustrated, and about to hand drawn them, now that saved me a lot of time, I can finally have all the construction details on the same level.
and Thank you too Matthew!
